whats wrong with the stock one.? i would only get it if you got some bigger and your jugs are ported or something and you think your bowls are running dry. but hey if you wanne spend the money on it just to have it go for it lol one more think to add to the list.
Edited by yamaha04
if the stock petcock/valve can't supply enough fuel to fill the carb bowls its time to invest in a pingel! (or a fuel pump). this is mostly the case with big bore stroker engines. if you are stock bore and stroke, don't bother with one.
ok i guess i dont need one because my motor and carbs are stock. the petcock i have on there now is leaking a little so i will just use the one off my dune tank for now instead off wasting my money.
