Spring Removal
it depends on what kind of shocks you have, but your going to need to compress them a little to take the pressure off the plates. after that the bottom one will noramlly slide off (depending on what shock you have) and then you just pull the spring off. it sounds ez but your not going to compress those springs by hand. you are going to need the right tools, espically if you are getting them pc'd. once you try to rig it up to get it back together you will scrtach the piss out of that fresh pc
