Someone else a little more "carb-savvy" might want to chime in but it sounds like you need to take a look at your jets like someone else said and your screw setting as well as for any kind of blockage in the jets.
Your carbs are definitely the problem it sounds like.
Be very careful with starting fluid, it's not good for your bike.
when i done my top end it wouldnt start on the first twenty kicks or so then i opened the throttle all the way and kicked once and fired. not necessarily tried to start but it did fire. the next kick it started up and idled and i have not had a prob with it. when ii rebuilt the engine i took off the carbs and tors and cleaned the carbs and put it all back together. similar to what you done. im sure you tried that (opened throttle all the way) but thats what it took mine to even get it to even attempt to fire. hope this helps
added note: maybe i should read the whole post before i post. lol
Edited by black dallas
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
