bansheeman1988 Posted January 17, 2008 Report Posted January 17, 2008 Would a fuel pump for stock banshee carbs benefit any, pry sounds like a dumb question, just interested in the idea. Quote
BigRed350x Posted January 18, 2008 Report Posted January 18, 2008 If you like fuel dumping all over your engine, comming out of your breather tubes and overflow lines from your stock carbs... then yeah, its a good idea. lol No, not needed with stock carbs. Get a pingel and you will feed more than those carbs could ever hope to guzzle. Quote
bansheeman1988 Posted January 18, 2008 Author Report Posted January 18, 2008 If you like fuel dumping all over your engine, comming out of your breather tubes and overflow lines from your stock carbs... then yeah, its a good idea. lol isnt that a good thing?? haha, no im not considering this just was wondering why some ppl use them. Quote
2strokespirit Posted January 18, 2008 Report Posted January 18, 2008 isnt that a good thing?? haha, no im not considering this just was wondering why some ppl use them. You don't need it, but if you put a return line it, it wont push your needle and seat open, I ran one on my 350 kart, because the tank sits just as low as the motor... Quote
dajogejr Posted January 18, 2008 Report Posted January 18, 2008 People use them for alky burning drag motors... When you burn alky in your bike you use twice as much fuel as you would gas. Plus, you're generally at WOT (sucking the fuel down)... People use a combination of things to get more fuel into the carbs....bigger bowls, remove a float, better flowing fuel valves...etc. Quote
06BaNsHeE Posted January 18, 2008 Report Posted January 18, 2008 Really on gas all you really need is a dual pingel.On alky its a different story tho. Quote
FireHead Posted January 20, 2008 Report Posted January 20, 2008 If you like fuel dumping all over your engine, comming out of your breather tubes and overflow lines from your stock carbs... then yeah, its a good idea. lol No, not needed with stock carbs. Get a pingel and you will feed more than those carbs could ever hope to guzzle. If I had ths inside of my cases powder coated, then it wouldn't matter................... :biggrin: Quote
bansh-man Posted January 21, 2008 Report Posted January 21, 2008 Would a fuel pump for stock banshee carbs benefit any, pry sounds like a dumb question, just interested in the idea. considering the pipes your running, you may have an engine unnig way to hot.... and with a fuel pump on that bike, you may end up blowing yourself up because that will cause the fuel to spill out of all your air lines and your carbs right onrto tyour engine and pipes.... ( heat = combustion) Quote
