I got so many chrome parts and not to mention the bearing carrier already for a stock axel for my drag bike but still haven't decided if i wanna start all over and get a drag axel. How many draggers out there run stock axels? Or is it just stupid to run a stock axel? I plan on riding at the dunes every now and then as well.
I used to run a stock axle and Badassbanshee379 uses a stock axle too. If you already got all your parts chromed for it.. run it. If your looking to shed as much weight as possible then you might want the drag axle.
Id just run the one you have. Drag ones are light but not that great for duning if you will do much. Not only that they are expensive!
Not if you know the right people....:)
If you plan on straight line drag racing only, get a drag axle. You wouldn't believe how much lighter they are...
If you're gonna dune, keep the stocker.
See i didn't think about that to, i can always have my stock axel if i go to the dunes and just switch it out with the drag if i go to the track it don't take long but as of now i'm just gonna get the stocker in there so i can have a rollin chasis and get everything else done.
Drag axles are 40mm and stock axles are 35mm. Gonna have to have 2 different carriers with different bearings.
Can also run a Raptor axle as it is -2 narrower and about 1lb lighter.
If you go Alum. you can also go with the JJ&A Hillshooter , thats what i run on my play bike!
True..... :whistling:
There is a heck of a difference in weight, if it matters. Lol
You got yourself a roller yet, Kaos?
