i have a stock stroke 68 mill cub.. has cpi inframes, 33mm pwks, vforce, u get the picture.. it has a new clutch with stiff springs and slips in 4th and up.. is a lockout best(dont really wanna go that route) or what about the fibers out of the frz1000 bikes??
ATF IS what you wanna use not oil. Did you use old springs maybe. Maybe need 3 or even 6 of the stiffer ones and good fibers like from the streetbike or just use one of Jeff's kits they're good over your bikes HP range. I've got a 400 cub and with 3 of the stiff springs and 3 stockers mine holds.
