LS1Inferno Posted December 17, 2007 Report Posted December 17, 2007 Up high in the revvs it just wont shift I've adjusted the clutch already, and the friction plates and steels are like new i already measuered them. Its an 87 completely stock except FMF pipes. Quote
wesw Posted December 17, 2007 Report Posted December 17, 2007 its a banshee they alll did that why do you think everyone with lot of power runs overrides and duneables. i think you can change some spring and other mods, Quote
wacko2000 Posted December 17, 2007 Report Posted December 17, 2007 Yea I was having the same prob with my shee on sat, I noticed it when I was on the shee hard and went to shift to 3rd Im waiting for Jim to get up and running again so I can go over a few things with him.. Quote
ClimbAnyHill Posted December 17, 2007 Report Posted December 17, 2007 I recently ported my Shee and yeah.. those symptoms exist on stock shees too. I threw in a Tusk Clutch, Pancake Bearing, Modified Shift Star & Shift Shaft, Shift Pro Kit. Don't have the overide but it shifts like butter! All shee's can use these mods + easy to install! Quote
dirt-riceburner Posted December 17, 2007 Report Posted December 17, 2007 I had the same prob under load even with shift star mod. We took the tranny apart and it seemed the shift forks looked pretty worn so we changed all three out. Now, it shifts very smooth at any rpm. Quote
LS1Inferno Posted December 18, 2007 Author Report Posted December 18, 2007 Everything is stock and i dont want to spend that much yet, whats the cheapest way to fix this. i had the trans apart a month or so ago and the shift forks were like new. Quote
bigboybanshee Posted December 18, 2007 Report Posted December 18, 2007 Did you check the shift shaft? It could be worn or slightly tweaked. Also, did you check the alignment of the shift shaft? Make sure the "claw" (for lack of better terms) is set correctly around the star or else it will give you trouble shifting. Also be sure that when you're riding, you drop your toe completely off the shifter after you shift...if you keep pressure on the shifter, it won't shift into the next gear...I caught myself doing this a lot last year, was causing me to miss shifts quite a bit. Quote
badassbanshee479 Posted December 18, 2007 Report Posted December 18, 2007 FAST racing offers a shift shaft mod, and an easy shift spring that helps with the shifting problems. I have also heard of people cutting every other dog off the gear clusters to help them shift better Quote
Snopczynski Posted December 18, 2007 Report Posted December 18, 2007 Wont shift in any gear, or just a certain gear (gears)? Please better describe the issue. Its definitely not normal for a banshee not to shift at high rpm. The trans will always work if nothing is broken, bent, worn, and your using good oil. Quote
LS1Inferno Posted December 18, 2007 Author Report Posted December 18, 2007 It wont up shift in ANY gear at high revvs, im using valvoline 10w30. I didnt pull out the shift shaft, but checking it is next on my list, and i take my foot away from the shifter. it physically will not let me click into the next gear untill its about 1/4 throttle. i REALLY dont want to tear the motor apart again. when i bought it,it was fine except someone ran it w/o oil and locked up 5th, but i put in a new shaft and gear. Quote
