razorbackbanshee Posted December 4, 2007 Report Posted December 4, 2007 When putting the ignition back on the frame do the spark plug leads go to the clutch side or the flywheel side of the engine. I think its the clutch side but not 100% sure. Also, which lead goes to which cylinder. Thanks, guys Quote
Bansh-eman Posted December 4, 2007 Report Posted December 4, 2007 it donest matter which side they go one as long as they will reach the plugs, but they fit best with the plug wires pointing towards the stator side. Quote
razorbackbanshee Posted December 4, 2007 Author Report Posted December 4, 2007 OK. Do you know which lead goes to which cylinder? Quote
jbooker82 Posted December 4, 2007 Report Posted December 4, 2007 OK. Do you know which lead goes to which cylinder? That doesnt matter. The banshee fires at both top dead center and bottom dead center. Both spark plugs fire at the same time. Quote
razorbackbanshee Posted December 5, 2007 Author Report Posted December 5, 2007 That doesnt matter. The banshee fires at both top dead center and bottom dead center. Both spark plugs fire at the same time. Great. Thanks. Total rebuild should be done tonight! Can't wait to fire her up! Quote
