205GTINUT Posted November 17, 2007 Report Posted November 17, 2007 Hi there Ryan from Ireland here. Heres the small problem, when i fire up my banshee from cold it starts no trouble at all but im noticing the left exhaust is a little more smokey than the right. When the bike is warmed up properly they give off an even smoke on rev. Anything to worry about?? Thanks guys. Quote
sled Posted November 17, 2007 Report Posted November 17, 2007 every banshee ive seen does that. i wouldnt worry about it. Quote
Stellar Performance Posted November 18, 2007 Report Posted November 18, 2007 Hi there Ryan from Ireland here. Heres the small problem, when i fire up my banshee from cold it starts no trouble at all but im noticing the left exhaust is a little more smokey than the right. When the bike is warmed up properly they give off an even smoke on rev. Anything to worry about?? Thanks guys. You could check the compression in the cylinders to see if they match. Do it cold, and then warm it up and do it hot. That way you can compare both readings. Might be time for a new rings and a hone. The main thing you are looking for is equal compression readings from each cylinder. Quote
Coupelx Posted November 18, 2007 Report Posted November 18, 2007 mine is setup about as perfect as could be and it still randomly smoked a little more out of each pipe when idling and starting :shrug: probably just some oil pudd;ed a bit some where Quote
