i have an 06 and i shaved the head and advance the time 6 degrees and it ran great. after about 6 hours the left cyclnder stoped fireing. so i changed spark plugs cleaned carbs swaped plug wires checked all elec. connections reeds look good. but whats weird is the cyclnder will die then start up then die and so on. it also will miss and pop out of that side. mods are t3's k&n's outerwears, shaved head adjt. timming plate. any help please.going to glamis for thanksgiving need it to be running cherry thanks
how much did you get taken off the head?
higher compression and +6 timing may have been too much for pump gas.
assuming that you run pump gas that is....
IM HAVING THE SAME PROBLEM BUT MINE HAS JUST PORT WORK AND A SINGLE CARB SETUP..TRIED SWAPPING COILS PLUGS EVEN TORE IT BACK DOWN AFTER I JUST PUT A NEW TOP END IN IT...COULDNT FIGURE OUT WHAT IT WAS SO I PUT HER IN TIME OUT(THE GARAGE).....BUT IF YOU FIGURE IT OUT LET ME KNOW...
Here's a link to one of my posts...mine was doing the same thing.....service manager clained it was the imulsion tube inside the slide...that was infront of his mechanics...once away from them he said that after the cylinders were put back on and it ran fine that he has no clue what the hell fixed my problem.....Maybe something here will help you. mY biekwa sin the shop for 3 weeks..worked on every day...paid $100 becasue they bent one of my needles and installed a new jet kit
EDIT: make sure the TORS is disconnected....
http://www.bansheehq.com/forums/index.php?...l=left+cylinder
i run 110 in it for gas. and also something else is my crank seals went out so i replaced them what if the two cases could be leaking? it was low on gear oil. i dont know how much was taking off my head he told me its the most i can take off
