spike Posted November 6, 2007 Report Share Posted November 6, 2007 I just got my hand on an RZ transmission, I mainly bought it for the forks and drum and also cause I needed the output shaft. now I'm wondering which one should I run. I will be running it in a 12 port stroker dune port from passion racing with shearer's and pwk33's I was also wondering what other tranny mods are out there besides the star Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted November 6, 2007 Report Share Posted November 6, 2007 if i had a rz trans i would run it.. pretty sure it has lil higher gearing and diff spacing between gears.... since it came from a rd bike.. Quote Link to comment Share on other sites More sharing options...
FireHead Posted November 6, 2007 Report Share Posted November 6, 2007 I would like to hear some other folks opinion on this as well. :thumbsup: Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted November 6, 2007 Report Share Posted November 6, 2007 Comparing the RZ tranny to the Banshee tranny; the RZ has a lower 1st gear and a lower 6th gear than the Banshee and 2nd thru 5th are higher than the Banshee. The RZ has a wider ratio spread for street and or racing. I would just keep your banshee gears and run the RZ shift forks and drum. Mike Quote Link to comment Share on other sites More sharing options...
hellride96 Posted November 6, 2007 Report Share Posted November 6, 2007 i would ask jim when he does your port work about his duneable override 1.5, thats what im runnin and i love it. Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted November 9, 2007 Report Share Posted November 9, 2007 (edited) The RZ does have a lower 1st and 6th, but in my opinion, run the RZ tranny. You can gear the ratios down with your sprockets and what I have found with the RZ gearing, if you gear your sprockets for a longer ratio the switch from 5th to 6th aint that big. My banshee with a 14-39 ratio on 20s if I switch from 5th to 6th, they gap is to big. Go with the RZ tranny, I feel the gears are spread better than a banshee's. My opinion. Edited November 9, 2007 by 2strokespirit Quote Link to comment Share on other sites More sharing options...
