Cubs are a pain too. Just make sure the rings are lined up with the pins and you should be able to get them in the cyl with your fingers.
Any one got any spit n chicken wire rigs to get ringed pistons into the cylinder?
Cut up pop can and zip ties. The only trick is you have to move the zip ties down the can with the piston. I usually do this when I am putting together something I don't have a ring compressor for. :geek:
