zach45 Posted October 23, 2007 Report Posted October 23, 2007 just took apart my brother top end.. the pistons bigger numer is 513m06650... i dont think there wisco pistons and the rings are real loose other then that the pistons look mint and bore seems to be good.. Quote
locogato11283 Posted October 23, 2007 Report Posted October 23, 2007 so what are you trying to do exactly?? Quote
zach45 Posted October 23, 2007 Author Report Posted October 23, 2007 anyway to tell the size or make of the piston? Quote
shee rips Posted October 23, 2007 Report Posted October 23, 2007 micrometer... im not sure how you would go about tracing the numbers back. Quote
blueshee03 Posted October 23, 2007 Report Posted October 23, 2007 thats the wiseco part number for a banshee piston with a 66.50 mm bore. Quote
xXBlessedWithDeathXx Posted October 23, 2007 Report Posted October 23, 2007 you can track the numbers threw weisco. if the bore is good i would just get rings. Quote
Bansh-eman Posted October 23, 2007 Report Posted October 23, 2007 thats the number that tells you what series and what diameter the piston is... Quote
zach45 Posted October 23, 2007 Author Report Posted October 23, 2007 thats the wiseco part number for a banshee piston with a 66.50 mm bore. how much over is that? Quote
Bansh-eman Posted October 23, 2007 Report Posted October 23, 2007 (edited) how much over is that? edit sry its 100 over did the math for a 65.5 piston ont 66.5 so i had to edit... Edited October 23, 2007 by Bansh-eman Quote
zach45 Posted October 23, 2007 Author Report Posted October 23, 2007 FUCKKK.. lol what does resleeving cost? Quote
zach45 Posted October 23, 2007 Author Report Posted October 23, 2007 i got a second motor thats has a bad bottom end ... but goot top end ... gunnna go get it tommmrow.. Quote
