Hi, I have a 89 shee with toomey t3 pipes in to a hush kit, ported lid, no snorkle, mikuni 28 carbs ( i think after market), kn filter with pre filter,vforce 3, stupid white bro boost,cool head, I bought it used, the owner also bought it used said he think it has a big bore kit. Right now the middle clip, 30 pilot, 345 main, 200-390 ft dep on area i ride, but will be riding in mass some too...
Edited by opt101
Your pilots may be too big, but that's not going to solve all your problems. Any idea what your compression is? Clean air filter? Also, check out FASTOYS profile, he's got a link to a PLUGCHOP that you need to perform to size your mains properly.
Here ya go check below:
I didn't know Mikuni offered a 345 main jet, you sure it's not a 340?
Either way...that bike is PIG FAT (Rich) for your mods....
With an airbox still in place and holes in the lids....you are feeding WAY too much fuel to that motor.
It could be 340(I looked at it a month ago, if I know I have one size up 350 that I was going to put in, but didn't so I figured it was 345), I now have the clip 2nd from top, changed the pilot to 35 from 30 and no more bog and revs and idle right back down like its supposed to, I got to check the mid and top end now, its raining rightnow, ill take it out in a bit...
just rode it, at 1/4 to 1/2 throttle has a gurgle then it kicks, should I lean the idle?
NO...1/4 to 1/2 throttle is the needle...
Move the clip up one towards the blunt end, see if it gets better...
I think 30 pilots is still too large with an airbox and a lid with holes in it...
Right now its at 35 pilot, when it was at 30 I had the low end bog, Now its at 35 2nd from top needle no low end bog, Idles down like its supposed to, but I have the 1/4 to 1/2 LOAD UP...
Edited by opt101
Have you actually tried adjusting the air screws from 1/2 turn out to 2.5 turns out, in 1/2 turn increments. Are you changing the needle the same time you're changing the pilot?
The 2nd time I did, Right now with the above post is my current set up, and I'm 1 3/4 turn out, The top end is perfect, start off is perfect, mid is prob...
*2ND FROM TOP
*340 MAIN
*35 PIOLT
*1 3/4 TURN OUT
Just for giggles, try this.
30 pilots. 1.0 turns out on the air screw, put the needle clip in the the 4th clip down from the top...
Actually, I had it that way the other day, Ran like a**
