opt101
    1989 Banshee Big Bore Kit Cool Head Mikuni Carbs
opt101's Achievements
  1. Took it up to tolland,ma yesterday, and its boggin under full throttle, then it kicks when you let off, what do you recommend for jetting, I will start freshl -300-400 Elevation sometimes I goto mass too... So it changes.. *Toomey T3 w/ Hush Kit *Vforce 3 reeds *K&N Filter with pre filter *1/2 holes Ported lid no Snorkle *Mikuni 28's *Big Bore ( I beleive) *White Bro, Boost Bottle (I order a cross over tube) *Cool Head *Run 32:1 Dominator Amsoil on Super Unleaded What Needle, Pilot, Main, etc should I start with.
  2. yes, I know how, they are now set a 2 turns out... same if not a little worse
  3. Do you think this will help *2ND FROM TOP *340 MAIN Going down to: *32.5 PIOLT
  4. Actually, I had it that way the other day, Ran like a**
  5. The 2nd time I did, Right now with the above post is my current set up, and I'm 1 3/4 turn out, The top end is perfect, start off is perfect, mid is prob... *2ND FROM TOP *340 MAIN *35 PIOLT *1 3/4 TURN OUT
  6. Right now its at 35 pilot, when it was at 30 I had the low end bog, Now its at 35 2nd from top needle no low end bog, Idles down like its supposed to, but I have the 1/4 to 1/2 LOAD UP...
  7. just rode it, at 1/4 to 1/2 throttle has a gurgle then it kicks, should I lean the idle?
  8. It could be 340(I looked at it a month ago, if I know I have one size up 350 that I was going to put in, but didn't so I figured it was 345), I now have the clip 2nd from top, changed the pilot to 35 from 30 and no more bog and revs and idle right back down like its supposed to, I got to check the mid and top end now, its raining rightnow, ill take it out in a bit...
  9. idle air is almost all the way in, need clipe 2nd from top, 1/4- 1/2 turn out on the air, runs like crap...
  10. lean it out one, really bad bog now
  11. wish i knew, bought it 2nd hand, it had lots of crap in there
  12. Hi, I have a 89 shee with toomey t3 pipes in to a hush kit, ported lid, no snorkle, mikuni 28 carbs ( i think after market), kn filter with pre filter,vforce 3, stupid white bro boost,cool head, I bought it used, the owner also bought it used said he think it has a big bore kit. Right now the middle clip, 30 pilot, 345 main, 200-390 ft dep on area i ride, but will be riding in mass some too...
  13. yea, I firgure pet cock, but I cleaned that it had a lot of dirt and metal shavings too on the screen, but it all clean now.
  14. Left Carb is getting good flow, right has the air pocket... could it be float?
  15. Hey guys, I have a air pocket that keeps comming back in my fuel line, any ideas, also I thinks its causing a low end bog
