yamaperv Posted October 17, 2007 Report Posted October 17, 2007 Ok kind of a dumb one I am trying to install my adjustable timing bracket and I can't get my flywheel off i got the nut off and put a puller on the flywheel and it won't budge there isn't a snap ring or something that I am missing or is there some easier way to get it off, I ordered a manual but don't get it till tommorrow and I wanna ride tonight Quote
RIPPEN Posted October 17, 2007 Report Posted October 17, 2007 Ok kind of a dumb one I am trying to install my adjustable timing bracket and I can't get my flywheel off i got the nut off and put a puller on the flywheel and it won't budge there isn't a snap ring or something that I am missing or is there some easier way to get it off, I ordered a manual but don't get it till tommorrow and I wanna ride tonight No snap ring or nothing... What kinda puller you trying to use??? RIPPEN Quote
yamaperv Posted October 17, 2007 Author Report Posted October 17, 2007 No snap ring or nothing... What kinda puller you trying to use??? RIPPEN All i can find is a two jaw right now I'm afraid to pull to hard cause I don't wanna bend it... Is it on a taper or what? Are they normally hard to get off? Quote
ranshee Posted October 17, 2007 Report Posted October 17, 2007 Dude you need to get a flywheel puller from motionpro or someone like that. Dont use a 2 or 3 jaw puller Quote
yamaperv Posted October 17, 2007 Author Report Posted October 17, 2007 Dude you need to get a flywheel puller from motionpro or someone like that. Dont use a 2 or 3 jaw puller Oh ok are they alot different or something... Oh well good to know Quote
ranshee Posted October 17, 2007 Report Posted October 17, 2007 Its a special tool with reverse threads. In the center it has a push bolt that you screw in and it pops the flywheel off. You can prolly find one for about 25 bucks. Quote
theshee Posted October 17, 2007 Report Posted October 17, 2007 Dude do not use a 2 jaw puller. You will jack that flywheel up. Get a good puller or plan on getting a flywheel. Quote
RIPPEN Posted October 17, 2007 Report Posted October 17, 2007 Dude you need to get a flywheel puller from motionpro or someone like that. Dont use a 2 or 3 jaw puller Good advice.. The 2 or 3 jaws are known to be hard on the flywheel and or stator.. DO NOT use those- lol.. As mentioned there is a actuall flywheel puller that works well and I believe is only 10 or 12 bucks most places.. Get that, its worth it!! Also when you do get one make sure you clean the threads out good so you can get threaded ingood.. Have heard of allot of people not doing that and end up stripping the therads on the puller.. RIPPEN Quote
jet mech Posted October 17, 2007 Report Posted October 17, 2007 One other thing to note: is to use a 1/2" drive impact gun/wrench for 1 you won't get it off and for 2 it won't stay on i used a 3/8 drive and it pulled it off but i rode it for 2 passes down the road and my damn fly wheel came loose so make sure you use a 1/2" drive other than that the job is very easy to achieve :beer: Quote
yamaperv Posted October 17, 2007 Author Report Posted October 17, 2007 Thanks guys that's what I needed to know or I would have really screwed it up. Quote
Snopczynski Posted October 17, 2007 Report Posted October 17, 2007 If you marked up the flywheel with the puller, or hit it with a hammer at all, get a new flywheel. Use approved factory like pullers only. Quote
yamaperv Posted October 17, 2007 Author Report Posted October 17, 2007 Now on the topic of new flywheels can a guy get an aftermarket one or is there any point? Quote
Snopczynski Posted October 17, 2007 Report Posted October 17, 2007 ricky stator is the only aftermarket one I know of. Quote
yamaperv Posted October 17, 2007 Author Report Posted October 17, 2007 does it make it faster or is it just a replacement part Quote
