Ok kind of a dumb one I am trying to install my adjustable timing bracket and I can't get my flywheel off i got the nut off and put a puller on the flywheel and it won't budge there isn't a snap ring or something that I am missing or is there some easier way to get it off, I ordered a manual but don't get it till tommorrow and I wanna ride tonight
No snap ring or nothing... What kinda puller you trying to use???
RIPPEN
RIPPEN
All i can find is a two jaw right now I'm afraid to pull to hard cause I don't wanna bend it... Is it on a taper or what? Are they normally hard to get off?
Dude you need to get a flywheel puller from motionpro or someone like that. Dont use a 2 or 3 jaw puller
Oh ok are they alot different or something... Oh well good to know
Dude do not use a 2 jaw puller. You will jack that flywheel up. Get a good puller or plan on getting a flywheel.
Good advice.. The 2 or 3 jaws are known to be hard on the flywheel and or stator.. DO NOT use those- lol.. As mentioned there is a actuall flywheel puller that works well and I believe is only 10 or 12 bucks most places.. Get that, its worth it!!
Also when you do get one make sure you clean the threads out good so you can get threaded ingood.. Have heard of allot of people not doing that and end up stripping the therads on the puller..
RIPPEN
One other thing to note: is to use a 1/2" drive impact gun/wrench for 1 you won't get it off and for 2 it won't stay on i used a 3/8 drive and it pulled it off but i rode it for 2 passes down the road and my damn fly wheel came loose so make sure you use a 1/2" drive other than that the job is very easy to achieve :beer:
