Hey Guys. Just got my motor all together.Mods in sig.Going to do some plug chops today.How do you know if the pilots are okay? The bike starts on first kick no matter what. Thanks!
Air screws...
Warm up the bike and set the idle slightly higher than normal. Seat the air screws and then turn out 1/4 turn each. Let the bike set for 20-30 seconds to stabilize and repeat. The idle should increase as you turn the air screws out.
If the highest idle occurs:
with the air screws less than 1.0 turns out from seated, bigger pilot is needed.
with the air screws more than 2.0 turns out from seated, smaller pilot is needed.
Ideally, you want the highest idle between 1 and 2 turns out. This is probably most useful if the initial pilot setting is close to what is required...
