What are you guys using that will tie into the stock hard brake lines? I want to keep the hard lines and just replace the old black lines to the calipers. what are you guys using that will tie right in?
We have custom vinyl covered steel brake lines made at a local shop called jfs hose and fittings in Sumner, WA.
and they will screw into the existing hard lines? what they run you? and you got any picts?
never seen a kit to do it but like snop said you can try looking up a local shop that does Hydraulics and take the distribution block to them and see if they can make a set of lines that will connect to the block and the callipers. take your soft lines with you so they can match the length.
