meanv10 Posted March 20, 2008 Report Posted March 20, 2008 That J arm looks like it will funnel dirt and sand down in to the Heim Joint pretty well :shoothead: So if you go from a j arm to a arm frame, can you use the same rear swing arm and carrier? also is there an advantage to changing to the new still carrier? Quote
Stellar Performance Posted March 28, 2008 Report Posted March 28, 2008 So if you go from a j arm to a arm frame, can you use the same rear swing arm and carrier? also is there an advantage to changing to the new still carrier? Everything is identical. When they switched to the a-arms style frame, they widened the upper arm mount to accept an a-arm. Thats it. The geometery, mounts, etc.....everything is the same. I would get with NYUK and pick up one of his a-arm frames with arms. If you are looking to get some different arms, PM me. Quote
jetskinjoe Posted April 5, 2008 Report Posted April 5, 2008 I've got the kit sitting on a shelf in my garage to go from J arms to A arms. I even have a set of stock a arms. Wanna buy it all? Cheap? Quote
1ugly88 Posted April 5, 2008 Report Posted April 5, 2008 I've got the kit sitting on a shelf in my garage to go from J arms to A arms. I even have a set of stock a arms. Wanna buy it all? Cheap? if he doesn't want it pm me with details and a price. Quote
