I am finally getting around to making these 34mm carbs work, but I need to find the following:
P6 dump tubes, and 30 pilots anyone have anything laying around they wanna get rid of? I went to Sudco.com, but they want to sell 4 of everything......that equals a lot of money when you are only starting out, and probably need bigger/smaller stuff in a couple weeks etc. other wise anyone will sell me two of each?
any recommendations on a needle?
these carbs are all wrong.....
current setup is 45 pilot, 150 main, RO dump tubes and 6fp63 needle.....
I plan on starting w/P-6 dump tubes, 280 mains and 45 pilot.....
I am at sea-level (Glamis) have "dune/drag" porting T-5 pipes, no air box milled head, 7degrees timing, lightened flywheel.......
w/stock carbs I have 27.5 pilot, stock needle, and 310 mains.....
thanks
c'mon someone has used flatslides before I am sure!
Can't say I have but I'm in the market for some 34mm flatslide's. Only place I really know of for those parts is Sudco like you said.
I've got a set of the TM flat slide 34's bored out to 35.5 on my dune bike. When I converted them to methanol I went to sudco. They sold me only what I needed, I dunno why they would try and sell you 4 of anything. Try calling them again.
Good carbs by the way!
- Jared
I have 34 mm keihns already converted for methanol, along with pro design intake (made for a big boost bottle, although it has been removed and capped off) I'd like to get rid of. I know they're 34 mm flat slide ..i think they're PJs...I can look for sure if you're interested.
