Honda 700XX
BenBB
yea, we've been discusssing the hell out of it over on the TRX site.
one of those deals where we don't really know how it'll work until we get on one but the general consensus is that it's a tad too heavy, otherwise looks decent and good potential for stroking for those motorheads. based on my xc background, i can't help but think how nice an IRS would ride.
The weight number of 508 is CURB weight. It seems Honda has changed how they are spec'ing these machines. Instead of DRY weight, everything now has a CURB weight, meaning every fluid (oil, tranny, coolant, fuel) is full. I like this. It was pretty common for DRY weights from the manufactures to be, ummm, optimistic. The Raptor 700 has a claimed DRY weight of 396, but in the real world with all fluids full they are around 440. So although this new Honda is portly, it's not as bad as it first appears.
Specifications:
Model: TRX700XX
Engine Type: 686cc liquid-cooled SOHC dry-sump single-cylinder four-stroke
Bore and Stroke: 102mm x 84mm
Induction: Keihin PGM-FI with a 44mm throttle-body fuel injection system
Ignition: CD with electronic advance
Starter: Electric
Clutch: Manual
Transmission: manual five-speed with Reverse
Driveline: O-ring-sealed #520 chain
Suspension Front: Independent double-wishbone with dual single-rate springs provide 9.3 inches of travel.
Rear: Independent double-wishbone with piggy-back reservoir shocks provide 10.6 inches of travel
Brakes Front: Dual hydraulic 174 mm discs
Rear: Single hydraulic 200mm disc
Tires Front: 21 X 7R 10
Rear: 22 X 9R 11
Length: 73.9 inches
Width: 46.3 inches
Height: 45.4 inches
Seat Height: 33 inches
Ground Clearance: 10.5 inches
Wheelbase: 50.0 inches
Turning Radius: 8.5 feet
Fuel Capacity: 3 gallons
Colors: Metallic Black/Silver, Metallic Black / Red
Curb Weight*: 508 pounds
Some Comparisons
off the mfg's websites.
...........................TRX450R................TRX700
Length..................72.6 inches.............73.9 inches
Width....................46.3 inches............46.3 inches
Height...................43.6 inches............45.4 inches
Wheelbase.............49.2 inches............49.8 inches
Seat Height............32.6 inches............33 inches
Ground Clearance...4.2 inches.............9.9 inches
Weight...................350 dry.................508 (curb)
...........................YFZ450R................ Raptor 700
Length..................72.4 inches.............72.6 inches
Width....................46.1 inches............46.1 inches
Height...................42.9 inches............44.5 inches
Wheelbase.............50.4 inches............50.4 inches
Seat Height............31.9 inches............32 inches
Ground Clearance...4.5 inches.............4.4 inches
Weight...................350 dry.................396 dry
Edited by sredish
Official Honda link
Ya that's purty hefty heh, I'd like a better look at that final drive tho, interesting setup...not gonna change sprockets in the pits between a preride and a race if its the same day I'll wager. Looks like some kind of eccentric for adjusting the chain hmm. Those are some massive front fenders...I'm thinking the Renegade 800 has a close rival in how much frickin' plastic there is hangin' on it, might be able to eject some mass there. Definitely better suited to Baja than ATVCCS, unless you put a snowplow on it and just mowed trees down lol!
