Nate-Dogg Posted September 12, 2007 Report Posted September 12, 2007 I was wondering if I should put any Lube on the lower rod bearings before I put the cylinders back on. If so What kind of Oil?(2-stroke oil) Sorry if this a silly ?, this is my first 2-storke rebuild and I have always thought the crank was sitting in gear oil(transmission). Thanks for the help! Quote
jbooker82 Posted September 12, 2007 Report Posted September 12, 2007 I ususlly dump some 2 stroke oil down there. You can put some in those little holes that go down twards the crank bearings as well. Quote
Bansh-eman Posted September 12, 2007 Report Posted September 12, 2007 what ever kind of premix your going to run... pour a small amount on both sides and spin the rods a few times to make sure you get it in there... other then that they are ready to go... the first time you fire it up it will smoke pretty bad but once you burn off the extra oil it will clear up. Quote
Bill Posted September 12, 2007 Report Posted September 12, 2007 Yea whatever 2-stroke oil you plan on using put A little on the crank bearings and rod bearings just so you dont have A dry start. Quote
Nate-Dogg Posted September 12, 2007 Author Report Posted September 12, 2007 Thanks for the quick reply's :beer: Quote
J-Madd Posted September 12, 2007 Report Posted September 12, 2007 BTW, the crank doesn't set in gear oil. It only gets oil from the premix. Quote
jedsled Posted September 13, 2007 Report Posted September 13, 2007 BTW, the crank doesn't set in gear oil. It only gets oil from the premix. thats crazy to think about that... Quote
