man i am no expert on jetting (currently having problems with my own lol) but if everything is put together properly (eg no air leaks, no blockages in the intake or carb etc) then just lean out the right side (by coming down in jet size and/or needle position) until the plugs look the same as each other.
the cylinders will never run exactly the same as each other, especially if it has been ported, because someone with a die grinder will never get two cylinders IDENTICAL to each other!
also man are the plugs the same?? ie the right plug isnt a colder plug (BR9ES or similar) is it?
