dutch350 Posted August 30, 2007 Report Share Posted August 30, 2007 what type of base gaskets and thickness do you use on a 421 cub. and a good place to order them.i also need the stud extenders. i tried jeff at fast but he is closed till tues. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 30, 2007 Report Share Posted August 30, 2007 what type of base gaskets and thickness do you use on a 421 cub. and a good place to order them.i also need the stud extenders. i tried jeff at fast but he is closed till tues. Thickness of base gaskets depends on what you want your squish to be...I run a thinner base gasket to decrease my squish, what works for me may not work for you. Vitos sells gaskets, several different thicknesses to choose from. Quote Link to comment Share on other sites More sharing options...
majicmike Posted August 30, 2007 Report Share Posted August 30, 2007 rob @ rdz has nice base gaskets that you can re-use vitos also is a good place as far as thickness where did you get the cub from? Is it ported? alot goes into the thickness. Quote Link to comment Share on other sites More sharing options...
majicmike Posted August 30, 2007 Report Share Posted August 30, 2007 Thickness of base gaskets depends on what you want your squish to be...I run a thinner base gasket to decrease my squish, what works for me may not work for you. Vitos sells gaskets, several different thicknesses to choose from. LOL posting at the same time and basicly said the samething Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 30, 2007 Report Share Posted August 30, 2007 LOL posting at the same time and basicly said the samething Great minds!!! :beer: Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 30, 2007 Report Share Posted August 30, 2007 Jeff uses 0.012'' thickness base gaskets on 421 Cubs.......just talked to him yesterday about one. Also.....I have an extra set of stud extenders if you need them fast, pm me. If this is a brand new Cub, do you have the water plugs? Quote Link to comment Share on other sites More sharing options...
dutch350 Posted August 30, 2007 Author Report Share Posted August 30, 2007 i bought the cub used from smkmupbanshee he did not know the thickness just said it was a vitos. can i use the regular 1 piece vitos that come in different thickness on a 68 mil because i noticed they sell a kit for the cub with a vitos 4 mil crank.i really dont need the whole kit , just the base gasket. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 30, 2007 Report Share Posted August 30, 2007 You can get the one piece base gasket. When you get it, make sure you trim the gasket to match the openings on the top case :thumbsup: Quote Link to comment Share on other sites More sharing options...
dutch350 Posted August 30, 2007 Author Report Share Posted August 30, 2007 thanks big. what squish do you recomend for race gas. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 30, 2007 Report Share Posted August 30, 2007 Glad to help! My squish is .039, runs great. :beer: I wouldn't run it any tighter than that, but usually the ideal squish is between 40-50 thousandths. Also, make sure you check the cylinder base nuts after each night of racing or couple nights of racing... I had mine come loose on me and I blew out a base gasket. I run a .012 gasket and its very thin, doesn't take much to slip out if the cylinders start coming loose. Also make sure you check the head nuts often too, I've got friends that say theirs come loose after a couple nights of racing, some after a few passes. I haven't had problems with my head nuts but wanted to pass along a pointer so you don't run into the same troubles. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 30, 2007 Report Share Posted August 30, 2007 I like between .040 and .050 squish, do you know how to check it. Majic...I'm surprised you don't carry them. Get yourself a digital caliper from Harbor Freight. I think I paid less than 30 for mine. It has become an invaluable tool, especially when you go to alky/methanol and have to start drilling shit...LOL. Quote Link to comment Share on other sites More sharing options...
majicmike Posted August 30, 2007 Report Share Posted August 30, 2007 I like between .040 and .050 squish, do you know how to check it.Majic...I'm surprised you don't carry them. Get yourself a digital caliper from Harbor Freight. I think I paid less than 30 for mine. It has become an invaluable tool, especially when you go to alky/methanol and have to start drilling shit...LOL. I do but I try to tread lightly plus glamis is about to start up and I am running low on stock right now Quote Link to comment Share on other sites More sharing options...
dutch350 Posted August 30, 2007 Author Report Share Posted August 30, 2007 J-MADD you have a pm Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted August 31, 2007 Report Share Posted August 31, 2007 The 4 mill 68 bore is supposed to have a .012 base gasket to get to a .01 in the hole deck thats what calvin designed them for. I have everything you need give me a call 877-301-1700 or go to http://www.mmatvonline.com Andy Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted August 31, 2007 Report Share Posted August 31, 2007 Just made me realize that the cub gaskets were not online ill have them on in bout 5 min Quote Link to comment Share on other sites More sharing options...
