I have tried to get these taylor wires to seat in the coil all the way but yhey wont reach or bottom out. I tried to shave back and remove the insulation but then it pushes the the center wire in and does not expand it..
called jeff at fast to no avail just everything else with this guy....... :down: it is what it is
Sorry , our phone has been wide open throttle and pegged out all week, im human and can only do so much. Just give me a call or your # via pm and i will call you back. It is a very easy install.
are you pushing them on or screwing them on?
I tried to twist push everything also lubbed it with wd40 brake kleen and dyelectric greese not happening. I drilled a little pilot hole into the side of one of the coil tubes where the wire goes in. I wanted to make sure i was geting a good contact.The wire is too fat or thick tried to strip away part of the insulation and it goes in but the nail or spike on the coil inside the tube that makes the contact with the wire, is not and it is pushing the center contact wire into the insulation.the inside tube of the coil is necked down about half way in this is where the wire stops and goes not farther.
Give me a call tomorrow and we will figure it out, and you also have a pm........
Get you a nology coil and put a regular spark plug boot on that end. That way if you want to change wires you just take them off like on a car. No pushing a cut wire on to a nail post or screw splice.
