jayzx10r Posted August 11, 2007 Report Posted August 11, 2007 I need to set up my front suspension. Lonestar recommends Positive Caster of 3-5*, Negative Camber of 2-4*, and toe-in at 1/4" for sand duning. Anyone think these settings are not the hot ticket?? Jay. Quote
odaen Posted August 11, 2007 Report Posted August 11, 2007 I need to set up my front suspension. Lonestar recommends Positive Caster of 3-5*, Negative Camber of 2-4*, and toe-in at 1/4" for sand duning. Anyone think these settings are not the hot ticket?? Jay. I'd set it up per their numbers and ride it. You'll definitely know if the front geometry is off when you ride it. Quote
jayzx10r Posted August 11, 2007 Author Report Posted August 11, 2007 I'd set it up per their numbers and ride it. You'll definitely know if the front geometry is off when you ride it. Do you set up to spec with a riders weight on the quad (race sag) or do you set up with the quad under it's own weight (free sag) only? Thanks, Jay. Quote
JKJK Posted August 12, 2007 Report Posted August 12, 2007 I have their arms+set them up to those specs at first.I found it was too twitchy+wanted to tank slap if i let go of the bars.For a good handling neutral ride for trails+dunes i ended up with.At ride height 6+pos caster,+1or-2 neg camber,1/4 to in.Use tie towns to strap down the susp when checking specs. Quote
jayzx10r Posted October 31, 2007 Author Report Posted October 31, 2007 (edited) Does anyone else have any pointers for setting up my front end for sand? I'm still trying to figure out if I should put sand bags on the seat to bring my quad to ride height or do the settings as it sits. Anyone have different spec recommendations that differ from the manufacturer numbers? One other Q....I have +2+1s. Is that +2 per side or +2 overall? Thanks, Jay. Edited October 31, 2007 by jayzx750 Quote
MotulMonsta Posted November 2, 2007 Report Posted November 2, 2007 I set mine up at the track. Took me all day. Then I went and got a steering stabilizer and it made a world of difference. Screw the bottom ball joints in as far as they go. If not, you'll risk bending them. I went through a half dozen ball joints before I figured this out. Then, measure the heim joints on the upper A-arms and ensure that you are getting no binding through the motion of travel and that it doesn't add to the bump steer. I honestly forgot what I set mine to..it was years ago and I haven't messed with it too much since. Those A-arms will last a long time! Quote
Bansh-eman Posted November 2, 2007 Report Posted November 2, 2007 jayz set it without any weight on the bike. Quote
letsgetthisdone Posted November 22, 2007 Report Posted November 22, 2007 7* of positive caster, 4* of neg camber, and 1/8" of toe in. thats what i ran for high speed desert riding, worked good in the dunes too.. Quote
zach45 Posted November 22, 2007 Report Posted November 22, 2007 pain in the ass... i on about my 6th time messing with them...... lmost got it Quote
rubberneck Posted December 8, 2007 Report Posted December 8, 2007 (edited) 7* of positive caster, 4* of neg camber, and 1/8" of toe in. thats what i ran for high speed desert riding, worked good in the dunes too.. These are almost the exact numbers recommended to me by Mike at ASR for my A-arms set up to dune with. He said about 6 degrees of caster, up to 4 camber and 1/8 toe. So since he recomended it and you said you had good luck with it, I am going to start there. Hopefully I wont have to monkey with them too much from there. Edited December 8, 2007 by rubberneck Quote
jayzx10r Posted February 11, 2008 Author Report Posted February 11, 2008 These are almost the exact numbers recommended to me by Mike at ASR for my A-arms set up to dune with. He said about 6 degrees of caster, up to 4 camber and 1/8 toe. So since he recomended it and you said you had good luck with it, I am going to start there. Hopefully I wont have to monkey with them too much from there. This is what I set mine up to today. 5 + Caster, 4 - Camber, and 1/8" toe-in. Quote
rubberneck Posted February 12, 2008 Report Posted February 12, 2008 I ended up at 6 pos caster and 2 neg camber, 1/8 inch toe in. Bike handles great. I didnt run the 4 neg camber because at that setting there seemed to be some binding in the steering when at full droop and turned max left or right. Quote
