Do these work on a banshee without a battery? Website says they only work for a 12 volt system. Does the stator put out 12V....haven't checked my RS with a volt meter...
http://www.radlites.com/billet_mount.htm
Yep. The stators put out twelve volts.
If you go to Pep Boys and pick up a set of the license plate Led bolts, and pick up 2 small L brackets from a hardware store, you have esentially the same thing at a fraction of the cost. That's what I did, and they are super bright and are for a 12v system.
If you need I can take some pics for ya...
  • 2 weeks later...
I'm using red LED clearance lights that would be used on a bus or tractor/trailer and have had no issues with voltage, at high RPM im interested to see how long they hold up to the approx 18V that the shee puts out at 8k+rpm, but i have 10 of em, so its no biggie... (BTW the lights were salvaged off of a totaled school bus from work)
  • 6 months later...
