OK so after placing the dead stator i had with a fresh one...
and now my banshee ain't running so great
it's fine at low RPM's
but when the motor revs up it kinda sputters and pops
there will be a split second or two where it clears up and rip then sputters again
now this is the case no matter what the position i hold the throttle at
whether i nail it and give it full throttle or just baby it and give it 1/4 throttle
its still not right when it should be hitting the power band
this the the first reason that i think its something electrical and not caused by the jets
now at first i thought it was lean
i normally ride with a pro flow K & N in the stock air box no lid...
so i figured to richen it up i would just throw the lid back on
it didn't change anything
so this leads me to thinks that its electrical
i am ready to take my bros stator off his quad - which i know is good
to see if the brand new one it defective as well
ill probably even try the cdi and coil as well should i decide to do this
Two weeks ago i did a leak down test to eliminate something on my list of things to check
it was fine after i scrapped down the some paint residue by the reeds
so now i am looking for some ideas...
i am pretty convinced its not the jets
and doubtful of the electrical being its the new stator
so i am pretty much stumped
can anyone give me some ideas on where tho head from here?
Edited by MattyMagee
What kind of stator did you buy. Ricky Stator is starting to get a bad name because of this problem.
Did you adjust the pickup coil gap on the stator after installing it?
josh
I would check the pickup coil gap. Also if you smacked or dropped the flywheel at all while replacing it, it ccan crack the magnets inside the flyhweel and cause the bike to run poorly.
UPDATE
i took the flywheel off inspected it for cracks like was suggested.
it came off a lot easier then any other time i had done this
so i was tthinknig that maybe i had screwed up putting it on.
anyway
i adjusated the pickup and it runs better then ever
thanks for the tips
