ok, i got an all stock banshee accept the toomey pipes and jet kit. My stock clutch is fried and i need one thats gonna last. Im doin lots of trails with sand and hills. Im thinking about the trinity one but i need help thanks........
I am sure some will disagree but w/a close to stock bike just about anything will do and last quite some time. I just replaced a TUSK in a 4 mill w/no lockup and an override after a year and a half of abuse. I will say though w/the addition of the override this year, I need a lockup.
I didnt have any luck with the cheapies. Im not stock tho either. I have a Trinity or a Toomey in mine currently. good clutch.
Bro, you're basically still stock motorwise....
Edited by MDS2106
If you want the clutch to last longer get some Barnett or Toomy Springs. use only 1/2 of them with a piped banshee.
That said I'm replaceing my 7 year old plates in my banshe ewith a ported motor. They are still good, but The backet was notched. Seriously any clutch should work for you, maybe you should think about using some decent oil like Bell-Ray gear oil.
I will be using the Tusk Clutch, Weisco basket, and a lockup clutch on a 4 mil cub.
Edited by Justintoxicated
You can run another stock clutch as long as you upgrade the springs. If you didn't break a plate or a fiber before, you will be ok with stock stuff and beefed up springs.
I run a wiesco basket with stock clutches and dirtbike springs,had dirtdigger clutches but they didnt last very long and a bud told me to replace them with the stock,so far so good. I have a mildly ported 4mil longrod stroker,also keep your oil changed regularly and use good oil like someone else mentioned that helps alot.
Edited by joneser4u
i put a tusk clutch in mine with a new hinson basket, new stock hub and p-plate about 2 yrs ago. all are holding up fine so far. clutch life really depends on oil changes and how much you abuse it though. but i can't complain about my tusk clutch kit as of yet. especially considering the low cost of them.
I would get a FAST clutch. I put one in my drag bike and its great. I use straight 30w oil, change it after every dune trip.
I have a 02 banshee and the clutch was a piece pf crap,, so i put a barnett in it and it works gr8 and it should last...
r
