depends on a lot of things, tires, length of swing arm etc. I think I would start with something like a 16/43,or 41
you should start with a 18/ 39 for 5 speed tranny asphault racing this will get you real close 16 /43 is a good sand gear
i have a 1 thru4 overide with bigbore sheerer inframe pipes and 39 pwk lockup i have the motor built already just want to have a good combo with this set up its for now on a stock swing arm i dont race it in the sand plain and simple asphault going up againsta 10 m 68 cub with his 38 mm pwk overide and all what do you gus think the outcome would be
OK SO ITS A STAND UP BIKE YOU WILL NEED THE 17 /39 AND WITH A 1-4 YOU WILL STILL SHIFT 5TH AND 6TH OR RUN THE 18/ 39 RUN 5 GEARS
AND YOU WILL NEED TO RUN SOME GOOD REAR TIRES LIKE HOLESHOTS OR RAZER 2 A STREET TIRE WILL HOOK TO HARD WITH A STOCK SWING ARM
