Hey guys I need your help I have just got my heads ported ( Dune Port ) 17cc domes, 6 degrees advanced, Vforce, Dual Pod Filters, Fresh top end standard bore and at 1000 ft elevation. Where should I start for jetting at? Any help would be greately appreciated Thanks
I am confused..did you get a Cool/Noss head with 17cc domes, AND a Dune Port? plus all the other little things
Let's back up...
At 1000ft elevation, did you get your crank trued and welded? if not...don't go any further...with that much compression on a stock, non-welded crank, you're sitting on a time bomb.
I hope you intend to use full race fuel as well.
What have you changed exactly since the bike last ran and was jetted correctly...?
With porting only, you may or may not have to go up a few sizes on the main, then a few more for pod filters if you had an airbox before....always better to start out rich and work your way down.
Its all trued and welded just the changes are Vforce3, 17cc Domes, Ported, and yes it was jetted perfectly before just a little lost this time I know I want to start rich but I don;t know how rich Oh yeh I dnt mind running race fuel Thanks
Ok...Ok...sorry to sound like a worry wart, but some people just don't realize that they're sitting on an EXPENSIVE time bomb if things aren't done right.
Honestly, I'd go up 3 to 4 sizes on the main....and buy a box of plugs.
You may or may not have to lean your needle out one clip...Vforce richen up the midrange, and if it's boggy....lean the needle a clip.
