peterlocal22 Posted June 30, 2007 Report Posted June 30, 2007 are there differnt size grease fittings. im getting a grease gun tonight and want to make sure i get the right size thanks Quote
suzuki0702 Posted June 30, 2007 Report Posted June 30, 2007 just a standard zerk fitting, make sure you get a gun with a hose not the solid tube. Quote
csrmel Posted June 30, 2007 Report Posted June 30, 2007 why not get one with a steel pipe? i have one and i can easily get all the zerka on the shee. Quote
XxMeltIcexX Posted June 30, 2007 Report Posted June 30, 2007 why not get one with a steel pipe? i have one and i can easily get all the zerka on the shee. Yep, just as long as it has a bend and can turn in the base. Eric Quote
MILO Posted June 30, 2007 Report Posted June 30, 2007 with my swinger skid plate on, there's no way i'd get to grease the bottom of the connecting rod without a flex hose on the grease gun. it sure helps with the lower a-arms also. Quote
shee4speed Posted June 30, 2007 Report Posted June 30, 2007 Mine gets greased after every bath which is after long trips duning or something. Quote
