hey yall, i can score a smokin deal on a pair of vm34 mikuni's.....deal is they are take-off's from i guy i ran into from a couple of his polaris sport 400 2-strokes.....outside of propper jetting, and changing out the choke controlls, what else will i have to mod to run these, and would it be worth it in the long run....i can buy these for 20 bux each!!
Other than rejetting, and changing the choke controls, there aren't any other mods, that you will need to do to the carbs, to run them. You will have to get new intakes for the 34mm carbs, and air filters. A friend of mine, used to work for the local Polaris dealership, and he also did the porting on my cylinders, and he told me about the Polaris carbs years ago. For $20 bucks a piece, that's a steal. :thumbsup:
Edited by fastbanshee8
putting bigger carbs on isnt going to do anything for you unless u have the mods to support them.
my bike is almost 70hp to the wheels on stock carbs and pump gas.....
another thing to remember is you will loose some low end with the bigger carbs also.....
Dan
For 20 bucks.....I'd buy them in a second. Spend another 20 in jets.
If you don't like them...big deal. Hold onto them until you get by the mod bug....then put them on.
Honestly, 20 bucks is flat out highway robbery....get for now, or later...or both.
