bodozer Posted June 20, 2007 Report Posted June 20, 2007 Just a quick question how much oil goes in the trans and does anyone know where i can get a new dipstick? thanks Quote
KaosBanshee44 Posted June 20, 2007 Report Posted June 20, 2007 1500 millimeters Says 1500cm on the side of the case which is 1500 millimeters Quote
okbeast Posted June 20, 2007 Report Posted June 20, 2007 mm is a distance measurement, not volume^^^ I think it's 1.8 quarts if you've just drained it and had the clutch cover off, and 2 quarts if you had the cases apart. Quote
dajogejr Posted June 20, 2007 Report Posted June 20, 2007 Drain and fill...1.75 qts. Complete dissasembly, 2.0 qts. If you have a lockup clutch 2qts on a drain and refil... Get a clymers manual... Quote
shanYE west Posted June 20, 2007 Report Posted June 20, 2007 (edited) 1500 millimetersSays 1500cm on the side of the case which is 1500 millimeters its 1500cc's is OEM fill level and I think you meant mililiters. 1500cc = 1500 mililiters Edited June 20, 2007 by Fouledout420 Quote
Snopczynski Posted June 20, 2007 Report Posted June 20, 2007 Anyone have a factory yamaha manual? Does it say to screw the dipstick in to check the fill level? Quote
okbeast Posted June 20, 2007 Report Posted June 20, 2007 ^^^ Nope, just set it in there to check. Quote
floyd398 Posted June 20, 2007 Report Posted June 20, 2007 In my factory manual it says 1.5 liters to fill after draining, which is almost exactly 1.5 quarts. (1L = 1.05 quarts), Nearly identical in this scale. So I always buy 3 liters or quarts of tranny fluid and have enough for 2 changes. Quote
SoCalinIt Posted June 20, 2007 Report Posted June 20, 2007 If you have a lockup clutch 2qts on a drain and refil... Word! Hey Dave... What tranny fluid are you using? Quote
dajogejr Posted June 20, 2007 Report Posted June 20, 2007 Word! Hey Dave... What tranny fluid are you using? The override I got from Jeff @ FAST came with instructions how to install it, how to break it in, and what kind/how much fluid to use. ATF Type F...2 quarts. Quote
SoCalinIt Posted June 20, 2007 Report Posted June 20, 2007 The override I got from Jeff @ FAST came with instructions how to install it, how to break it in, and what kind/how much fluid to use. ATF Type F...2 quarts. Yeah, the directions are in a box in the garage... Not too easy to find! Thanks for the quick reply! Quote
bodozer Posted June 20, 2007 Author Report Posted June 20, 2007 wow you guys ae helpful thanks alot Quote
SoCalinIt Posted June 20, 2007 Report Posted June 20, 2007 wow you guys ae helpful thanks alot Welcome to the HQ man! This place will be your home away from home! Quote
Washburn Posted June 21, 2007 Report Posted June 21, 2007 2qts on a change in a stock trans builds up to much pressure thus the oil doesnt flow as well. The manual states 1.6qts. I buy 3 quarts Motorex fully synthetic 30wt and have enough for 2 oil changes. This oil is good for wet chutches and will not soak in. I think its the best trans oil money can buy. http://www.ktm-parts.com/mm5/merchant.mvc?...t_Code=36030002 Motorex Synthetic Gear Oil 10w30 1-Liter Synthetic blend transmission gear fluid for use in all 2-stroke engines with a wet-clutch. Can also be used in 4-stroke engines with a separate transmission and wet clutch. Use wherever 75wt, 80wt, or 85wt Gear Oil for 2-stroke motorcycles is recommended. SAE 10w/30 (75wt/80wt), API GL-5 Quote
