FireHead Posted June 10, 2007 Report Posted June 10, 2007 well i guess im gonna get another set of pistons and c if they do the same thing seeing how tha machinisttold me the piston was not the same it lost a thousand and 1/2 but in order to do that i will have to give up my super stockers and the extra 6 hp i will have to get some boost ports to make up diff.well thanx guys been verry helpful next time to rebuild i will b going to the cubs think theres much of a diff in horse power or torque? To reiterate what Brandon said, make sure you inspect your cylinders before you do anything further. If you do not know how to measure them properly, ask one of us. :thumbsup: Quote
banshee(911) Posted June 10, 2007 Author Report Posted June 10, 2007 To reiterate what Brandon said, make sure you inspect your cylinders before you do anything further. If you do not know how to measure them properly, ask one of us. :thumbsup: i dont know how and or have the tool Quote
FireHead Posted June 10, 2007 Report Posted June 10, 2007 i dont know how and or have the tool You don't have a pair of calipers? Quote
banshee(911) Posted June 10, 2007 Author Report Posted June 10, 2007 You don't have a pair of calipers? what are calipers for brakes?i got some feeler gauges but i usually take them to a machine shop Quote
BlazinOne Posted June 10, 2007 Report Posted June 10, 2007 what are calipers for brakes?i got some feeler gauges but i usually take them to a machine shop I.D micrometer is the only way.Don't go more than .003 on cast pistons or .004 on forged.If your motor builder sets it up with any more than that ,he is a motor butcher,not a motor builder. I've rebuilt over 20 banshee motors and never had one clanking on me.All it takes is one time for some dirt to pass and your top-end will be torched. Quote
banshee(911) Posted June 10, 2007 Author Report Posted June 10, 2007 I.D micrometer is the only way.Don't go more than .003 on cast pistons or .004 on forged.If your motor builder sets it up with any more than that ,he is a motor butcher,not a motor builder. I've rebuilt over 20 banshee motors and never had one clanking on me.All it takes is one time for some dirt to pass and your top-end will be torched. thats what happend to mine in the begining of this post i put that i went through a sand cloud and after that it was the next day after i sobered up that i herd the noise i took my cylinders and pistons to the shop and he told me the cylinders was right where he put them but the pistons was down a thousands and a half Quote
blowit Posted June 11, 2007 Report Posted June 11, 2007 what are calipers for brakes?i got some feeler gauges but i usually take them to a machine shop I think your best bet it to take them to an engine expert and spend the 10 bucks to have the holes checked properly. We inspect at about 6 points in the bore to check for taper and out of round. Only then can you compare this data to the piston dims to determine clearance. Brandon Quote
FireHead Posted June 11, 2007 Report Posted June 11, 2007 I think your best bet it to take them to an engine expert and spend the 10 bucks to have the holes checked properly. We inspect at about 6 points in the bore to check for taper and out of round. Only then can you compare this data to the piston dims to determine clearance. Brandon I agree with Brandon. The inspection technique he describes is a bare minimum. As fishy as the whole deal sort of sounds, I think you need to find a way to root the problem in actual fact. :thumbsup: Quote
banshee(911) Posted June 15, 2007 Author Report Posted June 15, 2007 OK JUST GOT THE NEWS TODAY AS TO MY BUILDER WAS DYNOING SOME SLED HE TOLD ME THAT FOR ONE THING THERES ALOT OF PISTON CHATTER AND THAT THE HEAD WAS NOT CUT FOR THE NEW BORE Quote
