Quadatic20 Posted May 31, 2007 Report Share Posted May 31, 2007 Installing a new throttle cable is there an easy way to remove and put the two screws back for the cable stop in the carb? Anybody have a link for HELP??? Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted June 1, 2007 Report Share Posted June 1, 2007 These instructions may help: http://www.toomey.com/html/pro-ban.htm Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted June 1, 2007 Report Share Posted June 1, 2007 Installing a new throttle cable is there an easy way to remove and put the two screws back for the cable stop in the carb? Anybody have a link for HELP??? um, i'f i'm readin ya right your trying to do it wrong. unscrew the carb top, remove the slide/ carb top assembly, compress the spring as tight as you can get it, turn everything upside down and if the little gold colored metal keeper doesnt fall out in your hand then jiggle the throttle cable till it does. reverse to re-install... kehin's are alot easyer... Quote Link to comment Share on other sites More sharing options...
Quadatic20 Posted June 7, 2007 Author Report Share Posted June 7, 2007 um, i'f i'm readin ya right your trying to do it wrong. unscrew the carb top, remove the slide/ carb top assembly, compress the spring as tight as you can get it, turn everything upside down and if the little gold colored metal keeper doesnt fall out in your hand then jiggle the throttle cable till it does. reverse to re-install... kehin's are alot easyer... Got it thanks...it was actually easy. Quote Link to comment Share on other sites More sharing options...
