extreem9 Posted May 31, 2007 Report Posted May 31, 2007 So I have a banshee with t5's tommeys, cascade mufflers, 18cc domes it runs on 114 octane, Suposedly it has a good port and a slight over bored, 2 into 1 carb and a 4" extended swingarm. So the paddles that came with it are 22x11x8 9 extreme paddles and I can only see half of the extreme writing on the paddle, is it time for new , and if so would it be benificial to go with another 9 paddle extreme or do an 8 paddle. Quote
yfzdunejumper Posted May 31, 2007 Report Posted May 31, 2007 The tires sound fine I can't tell you how you are going to pull them Quote
dajogejr Posted May 31, 2007 Report Posted May 31, 2007 I'd say 8 paddle extreme or 9 paddle hauler. Quote
lowriderb Posted June 1, 2007 Report Posted June 1, 2007 if the 9 extremes are what was on there why not go back with the same tires.. if your wanting to try something different with the tires, you may want to just borrow a friends set to try out if they are a different roll out or paddle number or type.. Quote
badassbanshee479 Posted June 1, 2007 Report Posted June 1, 2007 I would put them on it and see if it will turn um good. if it spins real bad then worry about buying new tires! with the mods you have, you may have a hard time turning them tires on the top end. Quote
