phreak Posted May 19, 2007 Report Posted May 19, 2007 i have the motor completely unbolted from the frame and everything disconnected. but... for the life of me i can't get it to come out. i can wiggle it but only so much. i can tilt the front up but the rear of the engine hits the either the swingarm or frame (can't remember which right now). i can tilt the rear up slightly but the eye holes hit where the rear bolt goes to hold it to the frame. wft????!!!!! anyone have any tips or tricks on how i can get this bastid out? any and all help would be mucho appreciated. Quote
fastrthnu Posted May 20, 2007 Report Posted May 20, 2007 i have the motor completely unbolted from the frame and everything disconnected. but... for the life of me i can't get it to come out. i can wiggle it but only so much. i can tilt the front up but the rear of the engine hits the either the swingarm or frame (can't remember which right now). i can tilt the rear up slightly but the eye holes hit where the rear bolt goes to hold it to the frame. wft????!!!!! anyone have any tips or tricks on how i can get this bastid out? any and all help would be mucho appreciated. you got the stays off the bottom? you should just be able to jack it up n forward a little then pull it out the side. They are a little heavier than they look too. Quote
87sheerips Posted May 20, 2007 Report Posted May 20, 2007 make sure the gas tank is out, along with the plugs too :thumbsup: I usually take mine out the flywheel side of the frame. Nice and easy.... Quote
Wallrat Posted May 20, 2007 Report Posted May 20, 2007 There's 4 bolts by the exhaust ports, 1 at the top rear of the engine, and 2 underneath. Easiest way is remove the tank. Definitely pull the plugs. Lift the front of the engine straight up, slide the whole thing forward a couple inches to clear the top rear mount, then rotate it sideways and slide it out. Quote
Animalman294 Posted May 21, 2007 Report Posted May 21, 2007 I just remove the front and rear motor mount bolts, remove the front motor mount brackets, plugs and carbs. I then take off the torque bars under the motor and let them hang down. Then I slide it out the clutch side of the frame. Easy peasy-lemon-squeezy..................... :biggrin: Quote
KEVSWS6 Posted May 21, 2007 Report Posted May 21, 2007 Easy peasy-lemon-squeezy..................... :biggrin: :teehee: :woot: :yelrotflmao: I love that line! Quote
phreak Posted May 22, 2007 Author Report Posted May 22, 2007 There's 4 bolts by the exhaust ports, 1 at the top rear of the engine, and 2 underneath. sorry there are two more bolts underneath? faaaaccccckkkk!!! guess i gotta drop the skid plate then. makes perfect sense why she doesn't want to come out. thanks guys. :beer: Quote
swrbansheeboy Posted May 23, 2007 Report Posted May 23, 2007 sorry there are two more bolts underneath? faaaaccccckkkk!!! guess i gotta drop the skid plate then. makes perfect sense why she doesn't want to come out. thanks guys. :beer: that'd do it... Quote
KaosBanshee44 Posted May 23, 2007 Report Posted May 23, 2007 Did you ever get your motor out? haha Quote
phreak Posted May 24, 2007 Author Report Posted May 24, 2007 not yet. i'm gonna finish it up this saturday. get it boxed up and ready to ship it to rb racing. Quote
