have a quick question
you can put just about anything on there as long as its hooked up. if you still have the long vent hose on your gas cap you can cut a 4" or so piece off the end of it and use that. as far as your fuel delivery problem have you tried disconnecting your fuel line at the t where it branches off to the two carbs and opening the petcock to make sure the fuel is flowing at a good rate? if you do this and it's not flowing very fast you may need to pull the petcock out of the tank and clean it...
Edited by swrbansheeboy
