2002banshee05 Posted May 10, 2007 Report Posted May 10, 2007 is there sopossed to be a tube running from the right side of the left carb to the left side of the right carb .. like straigh across from the choke? Quote
01blckbansh Posted May 10, 2007 Report Posted May 10, 2007 is there sopossed to be a tube running from the right side of the left carb to the left side of the right carb .. like straigh across from the choke? YES that is the choke tube. if it is not installed your banshee may run rough. Quote
2002banshee05 Posted May 10, 2007 Author Report Posted May 10, 2007 without this choke tube will it have toruble getting gas to the cylinders?? Quote
Michael Jackson Posted May 10, 2007 Report Posted May 10, 2007 get a little ruber hose and jimmy nig that shit on there.. u need it Quote
2002banshee05 Posted May 10, 2007 Author Report Posted May 10, 2007 without this choke hose will it have trouble getting gas to the cylinders?? Quote
jlsparky7 Posted May 10, 2007 Report Posted May 10, 2007 When using the choke, yes. When not using the choke the carb grabs from the main fuel line. Quote
2002banshee05 Posted May 11, 2007 Author Report Posted May 11, 2007 alright cause im having trouble getting gas to the cylidners . so i thought maybe that this was the problem .... do i need anything special or can u just throw anything on there? Quote
swrbansheeboy Posted May 11, 2007 Report Posted May 11, 2007 (edited) you can put just about anything on there as long as its hooked up. if you still have the long vent hose on your gas cap you can cut a 4" or so piece off the end of it and use that. as far as your fuel delivery problem have you tried disconnecting your fuel line at the t where it branches off to the two carbs and opening the petcock to make sure the fuel is flowing at a good rate? if you do this and it's not flowing very fast you may need to pull the petcock out of the tank and clean it... Edited May 11, 2007 by swrbansheeboy Quote
2002banshee05 Posted May 12, 2007 Author Report Posted May 12, 2007 alright... any other ideas why the gas might not be getting to the cylinders?? Quote
chris1992 Posted May 12, 2007 Report Posted May 12, 2007 tke off ur carbs and clean them.. jets could be clogged.. take off your reeds and check them out.. make sure its all good in that department.. Quote
Snopczynski Posted May 12, 2007 Report Posted May 12, 2007 Fix what you know first, then worry about it if there is something wrong still. Quote
denty Posted May 12, 2007 Report Posted May 12, 2007 is there sopossed to be a tube running from the right side of the left carb to the left side of the right carb .. like straigh across from the choke? yeah that is right for the choke tube to be there Quote
