Looking into getting the toomey t'5 pipe set from rockey mountain. My question would be do i need to get anything else as in the hardware to mount these or like gaskets or anything? Or is everything i need with this. Also is it ok to run these pipes on a stock engine?(upgrades maybe in the future) And lastly some jetting help for these pipes on an all stock bike except k&n filter, 500ft above sea level, 70 to 80 degrees? Pilot 25 or 27? Thxs for any help!!!
Edited by Fastchecker
if you have a stock air box with the lid off and a k&n and a pro flow
and t5's....run your jetting in the 280-300 range for mains and stock pilots
if your getting the toomey jet kit run the needle in the 3rd clip position from the blunt end....
as far as the hardware goes i believe you can use all the stock hangers.
Dan
Yep, stock hardware should work fine...27.5 pilot and 280 mains gave me the best results. I'm at the same elevation as you are, and had the same mods back in the day. I ran the stock needles at the 4th clip from the blunt end.
Have you considered trying to find a used set of T5's instread of buying them new? They should be all over ebay
