ausbanshee Posted April 26, 2007 Report Posted April 26, 2007 How hard are they to remove??? thinking of more an appearance thing, trying to neaten up the bars a bit, and what the best way to COMPLETELY remove the key wiring? Quote
nunyabinness Posted April 26, 2007 Report Posted April 26, 2007 are you going to run with out front brakes??? you have to keep your front master cylinder if you want front brakes. Quote
ausbanshee Posted April 26, 2007 Author Report Posted April 26, 2007 (edited) fair enough, they're staying on then... :yelrotflmao: But can it be moved??? Edited April 26, 2007 by ausbanshee Quote
RoostRocket Posted May 1, 2007 Report Posted May 1, 2007 fair enough, they're staying on then... :yelrotflmao: But can it be moved??? im not sure if the front master cylinder can be moved but i know modquad and vitos sell a hide a key that works well i just ordered one myself! Quote
Lethaface Posted May 1, 2007 Report Posted May 1, 2007 (edited) I moved mine down to the fender crease..The stock wiring lenth is perfect and doesn't droop or anything like that.. Cleaned up the bars a bit as well.. I'm gonna add a water temp guage to the other side.. Looks better without all that cluttered stock crap.. Edited May 1, 2007 by Lethaface Quote
pokeatyou2 Posted May 3, 2007 Report Posted May 3, 2007 i just got rid of my key altogether just join he to wires that ran to the key together and you still hvae the complete circuit. then i just use the on off switch on the light switch and my kill switch to easy Quote
HardIzZlE Posted May 5, 2007 Report Posted May 5, 2007 get a hind a key it moves your key to under the seat i got 1 of ebay for 99 cents Quote
ClimbAnyHill Posted May 5, 2007 Report Posted May 5, 2007 Check this out: http://www.bansheehq.com/forums/index.php?...mp;#entry671360 Quote
KaosBanshee44 Posted May 8, 2007 Report Posted May 8, 2007 Yeah that's what i'm thinking about doin just hard wire it and use the on off switch. Who needs a key anyway just one more thing to turn on and off when you don't wanna ride anymore. Quote
xcracer160 Posted May 26, 2007 Report Posted May 26, 2007 i relocated my stock keyswitch do down where the reverse switch is on a raptor, and did away with the plastic cover crapon the steerign stem. i also run dirtbike bars so i ahve the low and mean feel i also liek the tag t2"s also had a good feel on the shee. but i would strongly reccomend relocatign the key if i wouldnt have relocated it i probably wouldnt have a shee right now. cause my girlfriends blaster got stolen and i am sur emy shee woudl ahve been next. Quote
dawarriorman Posted May 26, 2007 Report Posted May 26, 2007 i relocated my stock keyswitch do down where the reverse switch is on a raptor, and did away with the plastic cover crapon the steerign stem. i also run dirtbike bars so i ahve the low and mean feel i also liek the tag t2"s also had a good feel on the shee. but i would strongly reccomend relocatign the key if i wouldnt have relocated it i probably wouldnt have a shee right now. cause my girlfriends blaster got stolen and i am sur emy shee woudl ahve been next. Yep, hide a key makes it just a little harder to steal the quad. You hard wire it, you just made it a little easier. Why help a criminal? Quote
fastrthnu Posted May 26, 2007 Report Posted May 26, 2007 Yep, hide a key makes it just a little harder to steal the quad. You hard wire it, you just made it a little easier. Why help a criminal? I cut the key side of the harness, so you dont ruin the main side,. and being hardwired on the switch side you can just unplug it, and it wont run. Quote
