I'm changing my clutch basket to an after market one i was wondering if any one has used the wiseco basket and if so was it any good and does it come with good buttons. Well any way i was wanting to know if there is a step by step guide to remove the rivets holding the gear on any way if you guy could give me some tips that would be great thanks
chronicwatson
never used a wiseco but the hinson basket in our one bike has been working great for about 5 years now. since your ditching the stock basket center punch the rivets inside the basket and drill off the heads then punch them out...
Dont know anything about the weisco, but just about any aftermarket clutch
basket has to be better than the stocker.
The rivets are easy to drill out. They are made of some pretty soft metal.
Dont forget to use some red locktite on the bolts when you bolt the new
one back together. :thumbsup:
bend the tab down a bit, use a impact with 32mm socket i think or 1 1/4 not sure on that one. and buzz it out, change the gear can be a pain in the ass, make sure put washer behind it there is a big one behind it.
I just carefully ground the rivets off, then punched them out. Are you keeping the angled gear or going to straight cuts? If you go to straights you will need to press that small gear out of the angled one too.
