im looking at ITP HOLESHOT XCT TIRES fronts 23-7-10 and rear 22-11-9 so i can get more clearance in the trails.....are these good and how will it affect/change my low or high end power .....i got 13 front and 40 rear sprockets
what do you mean by more clearance? All holeshot tires are good. The harder the ground, the closer you want the lugs, looser ground get more separation. I do alot of it all mud,. fallen trees, hills sugar sand, gravel, so I use holeshot gncc.
clay, dirt, fields, gravel,. medium spacing. Hard packed, mx track, or on off road.... tight spacing. When I go into a track I use turf tamers.
I have that exact setup take a look at mine.... want measurements?
I have the best traction in dry grassy fields and trails are fine i never get hung up no matter how deep the ruts are just keep the speed up and it will glide over them on the skids lmao
hardpack and dirt roads are the best for getting sideways and spining 4th gear....... so dont drag on hard pack with XCT.....
Edited by LIM_Whiteboy4life
the larger the tire, u lose a little bottom and gain a little top.. also those xcr hook up well, for about a month, then they are shot, they wear out so dam fast, if your gona spend all the money for itp's, may as well go with some GNCC's, they are amazing, try them out, ive nevr had a tire hook up better than them,, the razr 2 is good too , not as good traction but better cornering and lasts a little longer,
Im telling you people use search. You'll see that kenda klaws for the front and stock yfz450 or kenda knarlys are the best for the rear
look in the mods or images forums, i have a post of what that exact combo looks like....
