qboronyrican
Everything posted by qboronyrican
  1. i think i was in 5th wide open then killed it
  2. thanks for the comments guys....ill try going up a bit more but i cant see going up too much more...already at a 162 main but ill try and if performance changes for the worse ill go back
  3. lean ....really? i thought it was pretty good....thought it was supposed to be a choc brown and 2mm in size? is that not dark enough?
  4. did a plug chop and looking for some opinions if its good...little lean....little rich. http://i43.photobucket.com/albums/e366/qboronyrican/plugchop1.jpg http://i43.photobucket.com/albums/e366/qboronyrican/plugchop.jpg
  5. figured it out ....dumbest mistake.....was a nest in the exhaust...must have gotten there from sitting all apart in the shed....lol...never even thought to check that
  6. got good comp., got spark.... im thinking it has to be a carb issue so time to take them off and check them out
  7. well thats what i was in the process of doing ....synced them by eye and then started it and thats when i noticed.....its a huge difference between the two so i dont think being out of sync a little bit would do that? unfortunately i dont have a comp tester handy
  8. these carbs are new to me i purchased them a while back and just now getting around to putting them on. but when i bought them i did take them apart and clean them up to have them ready to go when i got around to putting them on....its a fairly new rebuild with little ridding since the rebuild so i dont think its a internal problem but who knows!!!
  9. checked idle adjustments and both air/ fuel screws are 1 1/2 turns out....the stator side is the one with no smoke really not much pressure at all when holding my hand over it.....is there cross tubes that go from one carb to the other on these?
  10. have been putting the she back together after a long time waiting and i got everything back and now ready to sync the carbs....got it close by eye an started it up to check it with the sync tool and noticed that one pipe has a lot of smoke coming from it and the other barely has any at all.....what is the problem here before i continue and break something shee has 35mm air strikers btw
  11. not a problem....just hope we can get some answers
  12. just installed my new clarke 5.5 gal gas tank not realizing im going to need handlebar risers......can someone tell me how high i need to go to clear the tank and if im going to need to extend the cables and such???? i have Pro-Taper SE Handlebar atv-mids if thats needed info. also need to know if anyone has what i need for sale or where to buy what i need?.....thanks
  13. these are still available
  14. not sure yet about separate prices....rather see if i sell as a full set first
  15. would like to sell as a full set but if they don't sell then i would consider separating them.......full set $150 +shipping or ill even do $170 shipped depending on where your located
  16. plastics still available cant wait on people forever .......willing to trade for a set of white plastics in just as good or better cond.
  17. are these still available?
  18. so the carbs don't get connected to each other in any way? they work individually on their own?
  19. so they don't go anywhere? so do i need the tubes? do the carbs need to be connected to each other by any tubes or anything?
  20. did my leakdown test today and no leaks after 7 min it went down a hair ....maybe a 1/4 of a psi....so all is good....thanks for this thread
  21. anyone????
  22. i just added my 2-35mm airstrikers and it didn't come with any hoses. can someone please in detail explain how the carbs are supposed to set up....i do have this diagram but not sure if it applies to the banshee dual carb setup
  23. anyone in NJ ride in the pine barrens? im curious what type of tire/paddle is good for that area? haven't been there in many many years and dont remember the terrain type
  24. im also looking for a set of used haulers.....Preferably 21x11x8, either 8 or 9 paddles also with rims Send pics and price to [email protected]
