I fited my bike with Toomey T6 race kit. 280 main jet at sea level
When started it runs great on idle,but when i open the throttle it revs up and come
down real slowley or just starts runing away on its own.When i kill the swich only one
cylinder dies,the other one just keeps going(key off aswell)What can the problem be?
when you kill the ignition and the motor stays running that normally indicates a hot spot. carbon builds on your pistons and can get red hot causing the fuel to burn early or without a spark at all... in most cases it wont stay running though it will just diesel a few times and then die.
are you sure your electrical is hooked up right?
check your slides in the carbs for the cable binding a little. I have had that happen where the cable wasnt seated all the way in the cap and would run goofy like you described. Good luck- Erik
one more thing, ,mine would do the glow plug effect your getting as well. Thats what makes it not turn off even when you kill the switch. Lots of fun huh. If it happens putt your hand over the carba and starve the engine of air to kill it. Do you have the tors removed?
