qboronyrican Posted April 17, 2007 Report Posted April 17, 2007 i just bought a 02 banshee and wanted to know what jets should be in there for my application and what i should/should not do next to make it a little better.....this is what i got or was told what i got....boysen reeds(i think stock cages), barnett cluth, wiesco pitons, (recent rebuit top end assuming stock size but not sure) new chain, new sprockets-13/40, t5 pipes, boost bottle, idle kit, air box mod, stator @+4, and hi-flo impeller.....any help would be great....im new to this and don't know to much about the banshee.........im at a elavation between 220 and 680 and 40-70degress depending on where i go that day to ride Quote
Michael Jackson Posted April 17, 2007 Report Posted April 17, 2007 well one big thing is more info about your airbox setup or lack of... depending on what u got, it says "air box mod", what exactly is done to it? is it still there? Quote
qboronyrican Posted April 17, 2007 Author Report Posted April 17, 2007 well one big thing is more info about your airbox setup or lack of... depending on what u got, it says "air box mod", what exactly is done to it? is it still there? yea its there...its got a k&n filter and lid....the lid with a ram air scoop and vents on top....i think thats all thats done to it but i gota check to be sure Quote
qboronyrican Posted April 18, 2007 Author Report Posted April 18, 2007 somebody please....i know somebody with some experiance goota have some feed back for me........anybody??? Quote
sandman Posted April 18, 2007 Report Posted April 18, 2007 Sounds like you should be around 300 for mains to me. Welcome to the HQ. Quote
qboronyrican Posted April 18, 2007 Author Report Posted April 18, 2007 ok 300's for mains and anything else????? anybody??? Quote
jlsparky7 Posted April 18, 2007 Report Posted April 18, 2007 Start at 300 or even 310. Do a search for "plug chop test" and read some articles. Quote
fastrthnu Posted April 18, 2007 Report Posted April 18, 2007 ok 300's for mains and anything else????? anybody??? throw a noss head on it. your mains should be somewhere between 300-320. If your used to riding it the way it is now, you should look into some pods and porting. Jack that sucker up! Quote
okbeast Posted April 18, 2007 Report Posted April 18, 2007 I was thinking more around a 270 with the lid still on. Quote
qboronyrican Posted April 18, 2007 Author Report Posted April 18, 2007 thanks to those who helped so far.......is this gearing that i have a good setup for mostly trail ridding and some dune ridding? Quote
jlsparky7 Posted April 18, 2007 Report Posted April 18, 2007 That gearing should be fine, im at 13/41 riding trails and open sand areas and i like it. When i got my Paul Turner mids, .020 over piston .020 milled head and +4 timming ill be moving to 15/41 cause the bike will have too much low-end. Quote
BansheeDan Posted April 18, 2007 Report Posted April 18, 2007 That gearing should be fine, im at 13/41 riding trails and open sand areas and i like it. When i got my Paul Turner mids, .020 over piston .020 milled head and +4 timming ill be moving to 15/41 cause the bike will have too much low-end. actualy the 15 41 will make it have more low end then you currently have. when i did my build i started at a 15/41 and it was waaaayyy too much low end im now at a 14/40 and i think i need to go to a 13 tooth front...... i weight 125lbs and it just spins the tires with me on it Dan Quote
mpbanshee Posted April 18, 2007 Report Posted April 18, 2007 Going smaller on the front sprocket will make the low end better. A bigger front sprocket will increase top speed. Just remember that with a smaller front sprocket, you will be shifting alot more. Quote
qboronyrican Posted April 19, 2007 Author Report Posted April 19, 2007 so my gearing is good and i know where my jets should be......so whats a good next move for the engine.....best bang for my buck???? Quote
fastrthnu Posted April 19, 2007 Report Posted April 19, 2007 so my gearing is good and i know where my jets should be......so whats a good next move for the engine.....best bang for my buck???? porting :cool: Quote
