I'll be installing my K&N pods with outterwears tomorrow but noticed when removing the air box that it helped support the carbs! The air box hooked into these hooks on the frame to put pressure on the carbs to keep them from falling I'm guessing.
What do yous use or will I even need anything?
TIA
The rubber in the intake holds it fine. Ive got big ass filters and 35mm carbs and they arent going anywhere. It will work fine for you, no worries! :thumbsup:
Thanks.. I'll cut those hooks off to save the outterwears like you said. I was just worried the pods which are 6" would put too much force on the carbs and cause them to fall off. Now lets just hope the 300's I'll be putting in are big enuff!
Those 6"ers will stay fine. Mine are way big and hang fine.
If you're anywhere near sea level they won't be...
Typically run 330s to 340s with the T5's and pod filters, at or near sea level....60 to 80 degrees.
Bigger for colder temps.
Earthtools says I'm 115ft above sea level.. Jeff at fast asked where I was located and suggested 300 mains 30 pilots and needle on the 4th clip.. Should I go buy larger mains?
We're less than 800 feet above sea level here in MI, ride in 60 to 80 temps....
I've jetted 4 bikes in the last two years with Pod filters and T5 pipes. They ranged from 330 to 350, all stock port, stock motor bikes, one of which was my own personal 96...
At higher elevations 300 might be ok...but I think you're safer to start with a 330 and go from there.
Here's the way to find out for sure!
http://www.dfn.com/benkaren/plugchop.html
Thanks for the pics, I'll be sure to cut those off tomorrow. As for the Mains I'll grab some 330's and 40's as soon as my local shop opens in the morn. I bought the bike a month ago with T5's as the only upgrade and as far as jets they had 270 mains and 25 pilots.. The last two weeks I been installing all the other upgrades which is the Noss heads with 21cc domes, boss intake, v-force 3 reeds, timing advanced +4 and the pods. Tomorrow I'll be finishing it up and starting her for the first time will the upgrades. I guess I should have realized since it ran great in the upper RPM's before but was really rich in the lower RPM's that I should have jumped way higher on the mains with these upgrades. Will the 30's for pilots be ok or should I change?
Thanks for all the help guys!
Edited by RIPRuck
How's the bike coming along? Just wanted to say, DON"T cut those brackets off yet. You might want to put that airbox on eventually. Your engine will eat some big time mud and dirt around here. Just my two cents. :beer:
You might be right.. I'll see how the pods fit tomorrow, thanks for the advice! I really try to stay away from mud even with the box. Tomorrow will be the day I find out. Hows your rebuild comming? Is everything running good?
i rode at about the same altitude you are at... when i had stock carbs i ran 320's and i had my air box on without a lid... your going to probly need around that maybe 1 or 2 bigger.
Alright so I'll go with 340's but what do you think about as far as pilots and needle clip?
This thing RIPS!!!!! It's all set. The reason I say this is because I have a K&N, outerwears, airbox and lid. Everytime I come home, this thing is FILTHY. I never go out thinking I'm going to hit mud and water but it is inevitable around here. I'm the only other one around here with the two stroke to represent! Don't let some dirt and water kill your bike. Shoot me a PM when your ready to rip. :thumbsup:
