chevrolet banshee Posted April 6, 2007 Report Posted April 6, 2007 i just dumped about $700 in to my banshee rebilt the top end new sprocets and chain and a lot more so this morin i went to finish breaken the morter and i notised that it wos in 5 gear and wood not shift down so i figurid that it wood be fin wen it woremed up but it still dinint it will shift up but not down so i got 5 and 6 gear what the hell is rong with my banshee Quote
64xracer Posted April 7, 2007 Report Posted April 7, 2007 Could be your shift shaft. My shee did that a couple years ago when I was at the dunes, only mine stuck at 3rd, you could go up to 6th but not below 3rd. Cheep and easy to replace. Quote
chevrolet banshee Posted April 7, 2007 Author Report Posted April 7, 2007 Could be your shift shaft. My shee did that a couple years ago when I was at the dunes, only mine stuck at 3rd, you could go up to 6th but not below 3rd. Cheep and easy to replace. ok thanks Quote
trueraiderfan Posted April 7, 2007 Report Posted April 7, 2007 Dude you might get alot more answers if you spelled even a couple word's right. Quote
chevrolet banshee Posted April 7, 2007 Author Report Posted April 7, 2007 (edited) Dude you might get alot more answers if you spelled even a couple word's right. skru you Edited April 7, 2007 by chevrolet banshee Quote
scooter Posted April 7, 2007 Report Posted April 7, 2007 holy shit i think thats the worst post ive ever seen! Quote
banshee_blue_03 Posted April 7, 2007 Report Posted April 7, 2007 I think finding what is wrong with your banshee is the least of your worries......you first need someone to help you find the spellcheck! Quote
chevrolet banshee Posted April 7, 2007 Author Report Posted April 7, 2007 (edited) hay fuck all of you ok no realey Edited April 7, 2007 by chevrolet banshee Quote
Shee-Male Posted April 7, 2007 Report Posted April 7, 2007 after your done fucking everyone, pull your clutch cover and make sure the gear selector is still over the shift star, I've had a buddies slide off. I t could also be a bent shift fork, or a fucked gear set, but check the easy stuff first. Quote
chevrolet banshee Posted April 7, 2007 Author Report Posted April 7, 2007 ya i just got done messin with the shift hub and the shift shaft sliped off but i got it back on and it works fine Quote
Shee-Male Posted April 7, 2007 Report Posted April 7, 2007 hey hey there ya go, make sure you have the plastic spacer on the shifter shaft between the case and the stator cover, that will help prevent it next time :happy: Quote
chevrolet banshee Posted April 8, 2007 Author Report Posted April 8, 2007 ok thanks but thear is no spacer on the shift shaft Quote
